8
This discussion topic has been answered Discussion topic: Setting up - no DSL
This message was authored by: LD1996
Setting up - no DSL
We received the sky broadband router, coming from Virgin media (+before that, BT), but our open reach box doesn't contain a space for a DSL cable, only an Ethernet.
This message was authored by: jamesn123 Answer
Re: Setting up - no DSL
@LD1996
It doesnt look like your ONT has a power cable connected to it. Was this just for the photo or does it not have one?
I am NOT a Sky Employee
@LD1996 What did you order from sky as a package, are you expecting to connect back to a DSL fttc connection on a OR Master socket? Pictures take time to clear for viewing.
You sure have a fibre ont so only RJ45 lan connection on it to the Lan4 of the sky hub, take it you have a power adapter for the ONT as it is missing in your picture!
@LD1996
That looks like an ont the yellow ethernet plugs into lan port 4 on your sky hub.  No dsl cable required
This message was authored by: peter-marlow+1966
That looks  like  optical network terminal box like this one
 which  is for fftp broadband like I  have here and it looks like  in the photo  you have posted that you  don't  have  a  power lead, do you have one of these  outside of your  house
P c marlow
Avatar for LD1996
That looks very similar!
however nothing happens when I plug in the Ethernet cable to the router
Avatar for LD1996
Hi
This is the first thing we tried, as it's in the instructions, but receiving error messages with instructions to simplify the connection and a  "let's try to connect", which then doesn't work.
Appreciate the help 🙂
@LD1996 On the white ONT box that you have picture network connected, what LED's ar lit on it when tou look on the front off it?
@LD1996
Avatar for LD1996
This helped, you're right it wasn't plugged in, managed to find a cable for an old charger and it worked after that.
thanks!
