Discussion topic: Setting up full fibre
This message was authored by: Ly35
Message posted on 18 May 2026 01:32 PM
Does the sky hub need to be delivered prior to the engineer coming to install full fibre?
Find out more
Message posted on 18 May 2026 01:45 PM
Re: Setting up full fibre
It would be helpful if it was as the hub should turn up before the installation but if it dirsnt it is really easy to set it up yourself as you use the supplier cable from the fibre installation to connect it to a drive called the ONT that was be installed for you inside your property.
