4
This discussion topic has been answered Discussion topic: Setting up Port Forward on Sky SR203 router
This message was authored by: KenP2
Hello,
I want to set up port forward to a unit on my network which is connected via the SR203 Sky Router
So far I have gathered that it can't be done on the admin interface of the router (Crazy ??)  but is said to be possible via the My Sky App. However I cannot see any methods of Router management when I open the MySky app. All I see under Broadband is control of Broadband Shield and an offer to take up/cancel McAfee internet security.
Can anybody give me some gudance on carrying out this simple process which was a 5 minute task on BT Broadband (Those were the days )
Re: Setting up Port Forward on Sky SR203 router
@KenP2
https://helpforum.sky.com/t5/Broadband-Talk/How-to-set-up-port-forwarding/ba-p/2662260
@KenP2
The My Sky app is the administration method for the white Max Hub, not the black Sky Broadband Hub.
@KenP2
If you are trying to administer a Sky Broadband Hub, be aware that using Safari from a wireless Apple device typically doesn't work.
Avatar for KenP2
Thanks for the advice on the Sky App. @TimmyBGood  Won't waste any more effort in that direction.
I'm accessing the Hub via router login from a directly connected PC. Haven't seen any mention of port forward in the menus
Is there some other way to set Port Forward on SR 203 then?
@KenP2
