Discussion topic: Set up - only 3 green lights showing
This message was authored by: Aberdon
Message posted on 20 Oct 2025 09:21 PM
Initially installing new router 4 lights
came on, only lasted about 30 seconds, then appears to b stuck on 3 lights only!
tried to input password but unable to accept all digits!
Find out more
Message posted on 20 Oct 2025 09:25 PM
Re: Set up - only 3 green lights showing
@Aberdon this oage indicates what the lights on the hub mean https://www.sky.com/help/articles/hub-lights-explained-start assuming the internet light is green your hub is connected. With the password be very careful you are reading it correctly not misreading an 0 for an O which is very easy to do or a 1 for an I or vice versa.
