Discussion topic: Set Time-Based Internet Restrictions or Scheduled WiFi on sky Broadband
Message posted on 27 Oct 2025 07:08 PM
Hi,
I’m getting new broadband installed tomorrow. With my current router, I’ve set up a Guest WiFi network that I can turn off on a schedule to restrict internet access (for example, to control when certain devices can connect).
I’d like to set up something similar with my new broadband — either the same scheduled guest WiFi access or another method to automatically restrict internet access for specific devices or groups at certain times.
Could someone please let me know if this is possible with sky’s router, and if so, how to set it up?
Thanks in advance!
Message posted on 27 Oct 2025 07:26 PM - last edited: 27 Oct 2025 07:32 PM
Re: Set Time-Based Internet Restrictions or Scheduled WiFi on sky Broadband
@Shabeer No there is NO Guest mode with sky Hub's, if you have a sky Max hub and the additional Sky Max addon package then you will be able to use Parental Controls! Link to that help is below!
Parental controls with Sky WiFi Max | Sky Help | Sky.com | Sky Help | Sky.com
Depending on your current router and the connection type, you may be able to use it on a sky connection and have to do nothing apart from connect to the network then what you have at present will all be the same!
