2
This discussion topic has been answered Discussion topic: Service keeps dropping, however sky says it's fine
This message was authored by: Twr6
I have cameras, a hive system and fire alarm system all connected to sky hub. All showing no connection. This happens 3 or 4 times a day. My phone informs me when connection to them is lost. However when I use the sky app to see if the system is OK and the service has no problems. It always says it's fine and I have a good connection. Why does it show all is OK when I know it isn't.
Re: Service keeps dropping, however sky says it's fine
@Twr6
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
@Twr6
@Twr6 due to the limitation of how the service checker works it cannot pick up short losses of connection. However tge lights on your hub will show what is going on see https://www.sky.com/help/articles/hub-lights-explained-start
If those shows the connection is dropping then call Sky and report the issue as it nedds checking out. However the lights show the hub is connected and other devices are not affected the cause will be your Hive system misbehaving that is something you need to take up with Hive.
