Discussion topic: Service Checker - Speed to hub history
Message posted on 28 May 2024 08:40 PM
Touch wood, my connection is working fine 🤞.
Has anyone else noticed though that the Service Checkers speed to hub history, has stopped updating? My last update was 25th May....
Message posted on 29 May 2024 07:01 AM
Re: Service Checker - Speed to hub history
@gilbo2 my hub's history is updating normally last data id for 28/5. The data is drawn from the regular test and occasionally the tests fail or is down for maintenance. It could be worth logging out of the app and restarting it.
You can check your connection speed by looking at your hub's connection stats which will give you the downstream speed the unit is connected at see Find your Sky Broadband router statistics
Message posted on 29 May 2024 07:11 AM
@Chrisee , its shows no updates on the web based or app versions so it doent seem to be related to a login / logout. Yes, I can see my connection speed is actually 65488. I guess I could try a router reboot.
Not a big issue though 😉
Message posted on 29 May 2024 07:17 AM
Web based view (the checker front page always shows "last checked" within the last 15 minutes):
Message posted on 31 May 2024 07:40 PM
I did reboot the router but a few days on, still no updates. Most odd.
