21 Mar 2023 05:44 PM
All,
I am looking to segregate my home network, so that I have a lan for mobile, lan for pc and lan for TV.
This will make things cleaner for disabling certain lans.
Any advice on how I can go about implementing this.
I am a relative newbie to setting up a network and configuring routers etc; any advice would be welcome.
I have currently connected PC, Tv, Router and broadband all working with Ethernet cable.
mrplatypus
21 Mar 2023 05:58 PM
Posted by a Superuser, not a Sky employee. Find out moreFor a start you won't be able to do that with a Sky Hub: that's not functionality found in any ISP-issue router.
23 Mar 2023 10:24 AM
Posted by a Superuser, not a Sky employee. Find out moreYou'd need a pretty beefy 3rd party router to do this as its not a normal configuration.
Most people tend to use the guest network option on many router to connect their less important devices or those 'Chinese reporting devices'
