Discussion topic: Sent a hub after engineer fitted a new hub
This message was authored by: PaulLa
My broadband was updated to full fibre the engineer fitted a hub 29 may as mine was not received before the installation date. I have now received another hub in the post on the 30may.
Re: Sent a hub after engineer fitted a new hub
@PaulLa
I take it everything is working as it should do, if so you should be able to keep it as a spare.
Avatar for PaulLa
Level 0 icon
Worried I will double charged
