01 Aug 2023 04:26 PM
I'm getting ssl connection errors on Sky Broadband superfast over wifi - does sky block ssl?
01 Aug 2023 05:00 PM
@JaySam wrote:
does sky block ssl?
No, that would break the majority of internet services.
01 Aug 2023 06:43 PM
Try changing the Sky brodband shield settings.
01 Aug 2023 06:45 PM
Thanks, have disabled sky shield (and previously added the irl to the allowed), still no joy
01 Aug 2023 06:53 PM
It is definitely something to do with Sky brocking the URL becuase I can gain access to the site without issue and it has a R3 letsencrypt certificate which half the planet use.
01 Aug 2023 06:57 PM
That's useful, many thanks. I'll keep hunting down a solution
02 Aug 2023 08:51 AM
Just to add, I can get to the url via a browser, just not via 3 applications that try to access it - its these apps that give me the "The SSL connection could not be established" error.
02 Aug 2023 08:54 AM - last edited: 02 Aug 2023 08:59 AM
Posted by a Superuser, not a Sky employee. Find out more@JaySam From the additional info provided it's not Sky blocking it but the apps, as you can access the url via a web browser on Sky broadband without any issues then the apps your using are to blame.
There may be settings within these apps that need to be amended.
If you let the forum know which apps are cuasing the messages we may be abe to help further.
02 Aug 2023 08:57 AM
Thanks for this, helpful I'll initially reach out to the apps provider to see if they can help,
