Discussion topic: SR213 Router - Manually Enter IP details for port forwarding??
This message was authored by: JamesD19
Having issues with port forwarding on my Hkvision NVR. Only way i can get this to work is to enable UPNP on device and on the router and I dont want to do that. But this method works.
Its already a pain you cant configure this on the router and have to use the app, but are Sky planning on having a box to manually enter an IP address of a device, rather than picking from a DNS name as the device does not show unless UPNP is on? Then obviosuly this is pointless setting up a rule.
Please like this post if you are having issues with port forwarding like this and also want Sky to add in a manual box to manually enter an IP address.
Also if anybody knows if this is already in development?
Many thanks in advance all.
