Discussion topic: SR213 Hub Ethernet Issues
This message was authored by: Swampy_B
Model: SR123 Hub6 v1
Installed: July26
Issues Started: July26
Joined Sky from Virgin, no previous issues, super speedy connection, move was to save money.
Setup:
2x Cat6 structured cables from router to office
  • 1 to MS Dock
  • 1 to New Max Pod
Issue:
Ethernet Speed Tests limited to 250Mbps, never goes above.
Wi-Fi Speed Tests > 700Mbps
Tests:
Cabling
  • Swapped structured runs = 250Mbps
  • used single Cat6 from router to dock = 250Mbps
  • Plugged dock into Max Pod = 350Mbps
Hardware
  • New Dock tested = 250Mbps
  • New Router = 250Mbps
Visits
  • 2 Sky Engineers
Any ideas?
This message was authored by: Me134
Re: SR213 Hub Ethernet Issues
Installed: July26
Setup:
  • 1 to MS Dock
  • 1 to New Max Pod
Issue:
Tests:
Cabling
Hardware
Visits
  • 2 Sky Engineers
Any ideas?
Which make and model of a Microsoft Dock are you using?
You say ethernet speed tests are limited to 250Mbps, is that via an ethernet device connected directly to the hub?
What speed does the MySky app report to the hub over the past few days?
Not a Sky employee
Sky FTTP 500Mb to Max Hub
Avatar for Swampy_B
It's a Microsoft Surface Dock.
Ethernet connection from Dock to Hub
Speeds into property are >700mbps consistently.
its just Ethernet which appears to be struggling with throughput.
Given your testing with the cables and wifi, the issue appears to be the dock, no idea why VM would have been different though.
If you have one, test the tablet itself with a USB-C to Gigabit Ethernet adapter plugged directly into the router. If that's fine then it's down to the dock, there's a link to the Surface internet diagnostic tools in the following thread if you haven't tried them yet.
https://learn.microsoft.com/en-us/answers/questions/2297516/surface-dock-ethernet-speed
Not a Sky employee
