31 May 2022 01:40 PM
Hello All,
I've noticed that all of sudden port forwarding has stopped on my SR203.
This is an issue for me as I need remote access to my server via OpenVPN.
The settings are in the screenshot below:
Can anyone advise if this is a user issue or a router issue. I'm heading to another country soon and need to have remote access to my server.
31 May 2022 02:17 PM
Posted by a Superuser, not a Sky employee. Find out moreFor starters have you switched your router off for 20mins to fetch a new public IP?
31 May 2022 06:43 PM
31 May 2022 07:37 PM
Turned the router off for 30mins.
I've checked it's a new public IP and still port forwarding is not working.
Is there anything else I can try?
01 Jun 2022 04:33 PM
I spun up a test webserver and tested the pre-build service rule for port 80 and still this is not working.
02 Jun 2022 04:25 PM
Hi @jamesn123
Thank you for you help. Turns out the issue was on the VPN server itself. I had an incorrect netmask.
Port forwarding is working and I can access my serevr remotely using the VPN again.
