Discussion topic: SLY MAX POD
This message was authored by: adamfinch83
SLY MAX POD
Hi guys,
I went into WiFi settings on my sky app and turn ed off 2.4ghz and 5ghz WiFi on my sky max pod. Now it's not connected and I have no way of turning the WiFi on the pod back on (as it's not appearing in the app) There's no way to reset to pod. I've unplugged it, there's no other buttons.
please can someone help?
silly I know, but thought I could turn it back on!
thanks
Re: SLY MAX POD
@adamfinch83 Is there NO pinhole anywhere on the pod to put a paper clip in for reset!
Avatar for adamfinch83
Level 2 icon
Re: SLY MAX POD
No pin hole, just 2 ethernet ports.
No way to remove it in the app, just re-connect but it wont re-connect, tried adding serial number instead of scanning QR code but nothing.
Re: SLY MAX POD
@adamfinch83 Seems there is no reset function to the actual pod, it's all done through the software on the app, and removing power to the pod get's it all ready to setup again!
Level 2 icon
Re: SLY MAX POD
Yes thats what it seems, but i disabled the wifi via the app and it needs wifi to connect obviously. powering it on and off doesnt seem to reset. So im a bit stuck it seems. It needs a hard reset somehow!
