Discussion topic: SKY Max Hub
This message was authored by welshguy2017 This message was authored by: welshguy2017
SKY Max Hub
Is it worth paying the extra £10 a month for the new router? I am having Ultrafast 500 Mbps installed on the 18th. I currently has the SR203.   Thanks
Re: SKY Max Hub
@welshguy2017
Depends if you have WiFi 6 devices & whether you need that extra speed. The majority of WiFi connected devices are not going to see any benefit of speeds above 50mbps or so.
I am NOT a Sky Employee
Re: SKY Max Hub
Possibly if you are likely to be claiming booster pods or need the Parental Controls.  For just the Hub, that's a substantial price rise which few devices will benefit from.
