Discussion topic: SKI Max Router - Delete IPv4 Reservation
This message was authored by: ChrisOnSky
When logged on as Admin I need to be able to delete an IP Address reservation.  Issue is that when the reservation is originally created you provide the computer hostname. But if you have a laptop with a port replicator and then the laptop is replaced there is a hostname problem.
It is a design flaw to be able to create an object on a computer without abilty to delete it.
The interface doesn't allow changing from Reserved to DHCP either, when the utility closes then it has reverted.
Resetting the hub is totally unacceptabe because there are multiple devices connected to the network and then a lot of reconfiguring is required.
As Sky has known about this for many months with no apparent action, I am thinking about switching to a different service provider.
This message was authored by: cassally
Re: SKI Max Router - Delete IPv4 Reservation
You could buy your own Router (Modem if you are on VDSL2) and Access Points 😉
Devices will be yours and you can set whatever the device is allowing you .....
some devices are better then others and come with updates longer then others .....
I do not own or need 😉
- xx" 8K/4K TV
- sound bar
- games console
