Discussion topic: Running Ookla Speed Test
Message posted on 05 Apr 2025 11:09 AM
Why does it say on the app when I run it on my pc, that my broadband suppier is Amazon and not Sky.
Thank you
Message posted on 05 Apr 2025 12:58 PM
Re: Running Ookla Speed Test
@Barry-P wrote:Why does it say on the app when I run it on my pc, that my broadband suppier is Amazon and not Sky.
Thank you
Speedtest will chose nearby servers to your location and choose the server with the lowest response time hence, in your case, Amazon.
See How does Speedtest select a server?
Sky Q 1TB UHD
LG TV
Sky Mobile
Message posted on 05 Apr 2025 01:54 PM
When I run the app there are two names one above the other in the bottom left hand corner. The bottom one to my understanding is my broadband supplier and the top is the name of whoever is running the test and like I said its showing mybroadband supplier as Amazon. I hope that explains my question better thank you
Message posted on 05 Apr 2025 03:06 PM
@Barry-P wrote:When I run the app there are two names one above the other in the bottom left hand corner. The bottom one to my understanding is my broadband supplier and the top is the name of whoever is running the test and like I said its showing mybroadband supplier as Amazon. I hope that explains my question better thank you
Oh i got you. In that case I'm unsure why your getting that. If everything is working okay then i guess its not something to be too concerned about.
Sky Q 1TB UHD
LG TV
Sky Mobile
Message posted on 05 Apr 2025 03:30 PM
@Barry-P It happens occasionally when they have mistakenly identified your IP address as belonging to a different provider.
Message posted on 05 Apr 2025 04:03 PM
Ok, thank you for your replies.
