Discussion topic: Router won’t connect to sky box
This message was authored by: Helenkelly
I've done all the checks and there seems to be no problems with our WiFi but the router won't connect to the sky.  It's gone off today. Is there anything we can do to fix it.
Re: Router won’t connect to sky box
@Helenkelly
If a reboot doesn't fix it then the the first thing to check is this link to see if there are any outages in your area:
If there isn't try running the line test here:
If this is if no help give Sky a call to report it to them.
