Discussion topic: Router won't connect to Samsung TV
Donna--
This message was authored by Donna-- This message was authored by: Donna--
Re: Router won't connect to Samsung TV
Unfortunately no fix for me either.
I have to connect to my mobile hotspot to be able to use my Smart TV.
No help from SKY. I guess I'll have to put up with this for the next 2 years!!
This message was authored by Howmanyshoes87 This message was authored by: Howmanyshoes87
I did try again when I got in today and it did connect to sky wifi the usual way with the password. No idea why. Guess I'll see tomo if it remains connected! My advice is persevere with trying as it may work one day!
Donna--
That's good to know.
Thank you so much for your input.
  • Much appreciated.
    @Donna-- wrote:
    Router will not connect to my Samsung smart TV. I've reset the router and the TV. Switched them off and back on again - nothing! TV will only connect via WPS pin, but only briefly, then has to be reconnected again. All other devices will connect to router, but not the TV. TV will connect to other WIFI networks, just not the one I'm paying a fortune for!!
This message was authored by Lizzie231 This message was authored by: Lizzie231
Update. I changed the security setting to WPA2 rather than the default 3 and it worked!!
My Sky app
Broadband
WiFi settings
Advanced settings
WiFi security level
Change to WPA2.
This message was authored by Kate218 This message was authored by: Kate218
Hi, I can't see any option in my sky app to adjust the security settings. Can you help
please? 🙂
WiFi settings
Advanced settings
WiFi security level
Choose WPA2
