Discussion topic: Router replacement
Message posted on 13 Nov 2025 12:26 AM
Router replacement
Hi I had a guy coming to me house today he installed new router but in different room he said he can't connect in the room which was previously but we had a cameras security connected to the previous router and now cables are to short to rich new router is any help from you in this case ?
Message posted on 13 Nov 2025 12:35 AM
Re: Router replacement
@AlicjaB It is upto you now to move the sky Hub to were it is best needed. If you had a Fibre install done the cable from the ONT to the sky Hub, the length you require to get the hub moved to the position that you need it in! Cat5e is really all that is required, look on Amazon will give you the idea off lengths/price standards!
