Discussion topic: Router range Issue
Message posted on 20 Oct 2025 11:15 AM
Router range Issue
My router is not strong enough to give me coverage in my small 2 bedroom flat. Next to the router, the signal is fine and speeds are adequate.
At the other end of my small flat, there is no wifi signal at all. ~12m away from the router. Note that it's not possible to move the router due to the placement of the port
Message posted on 20 Oct 2025 11:55 AM
Re: Router range Issue
@cavendish8S Depending on what you have will sky be able to help you, the information linked below may be able to assist, but would be FAR better to relocate the Hub with a longer cable to a more central location!
getting sky max and how to get the pod's
https://www.sky.com/help/articles/enhanced-wall-to-wall-wifi-guarantee
