2
This discussion topic has been answered Discussion topic: Router problem
This message was authored by: Bill-S1
Router problem
My download speed at 109 is normal but upload, on testing, reads 2856 mbps which I consider unusual. Any suggestions?
Avatar for Bill-S1
This message was authored by: Bill-S1 Answer
Re: Router problem
Thanks JimM1, I had a look and the reading was definitely Mbps - however I have  since run the tests on 2 i-pads and the readings are perfectly normal!  The problem appears to be with the PC and maybe the settings etc.
Re: Router problem
@Bill-S1 Use another testing system to see what is different Some programs may do kb/s if so do the conversion..
Avatar for Bill-S1
Re: Router problem
