Discussion topic: Router not working.
Message posted on 18 Jul 2026 05:46 PM
Router not working.
I have been having Internet issues. My router is not connecting. Cannot use wifi. Cannot watch smart TV.
Message posted on 18 Jul 2026 07:37 PM
Re: Router not working.
@Foxk wrote:I have been having Internet issues. My router is not connecting. Cannot use wifi. Cannot watch smart TV.
Presuming that this is a wifi issue rather than the broadband to the house.
Firstly, unplug the hub for 10 minutes and then reboot, hopefully a channel rescan will find a less congested wifi channel.
Have a look at the following to see if they can resolve your problem easily if no success with the above, you can also use the MySky app. If not you may need to consider either the Sky WiFi Max add-on package or perhaps purchasing a 3rd party mesh system (which remains yours regardless of ISP used and would be my own personal choice).
To check on local outages.
To run the local checker.
https://www.sky.com/help/articles/broadband-diagnostic-start (do run all tests)
Helpful articles that explain the basics.
https://www.sky.com/help/articles/broadband-speeds-explained
https://www.sky.com/help/articles/broadband-tips-when-working-from-home
Link for Sky WiFi Max
https://www.sky.com/broadband/wifi-max
Not a Sky employee
Sky FTTP 500Mb to Max Hub
