Discussion topic: Router not working
This message was authored by: Johncooper01
Router not working
The WiFi goes off multiple times a day. If I try to use WiFi more than 5 metres away from the router it won't work
Re: Router not working
@Johncooper01
A poor signal in certain rooms is something that comes up on here on a regular basis so try going through this to see if it helps:
https://www.sky.com/help/broadband/my-broadband-speed/improving-wi-fi-signal-to-my-devices/articles/...
If not and if you have Wi-Fi Max on your account then Sky will loan up to 3 pods as you can read about here:
So you can either call them on 150 from a landline phone or a mobile that has a Sky sim in it or Select "No, I still need help" at the bottom on the above link.
