Discussion topic: Router not working
This message was authored by: Rachel80
Router not working
My internet isn't working
Re: Router not working
@Rachel80
The first thing to try (even if you’ve already tried it) is to use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
