Discussion topic: Router not working
Message posted on 18 Oct 2025 04:35 PM
Router not working
Ted light on the router no service yet the checker say all is connected
Message posted on 18 Oct 2025 04:41 PM
Re: Router not working
Power light goes from red to green but no other lights are on. Is there a transformer issue?
@SteveHarding
Use this link to check to see if there are any broadband issues or outages nearby.
This should determine if there's an identified fault, perhaps affecting multiple households. (It doesn’t necessarily disclose a problem instantly and it takes a little while to update so perhaps try again an hour or so later).
