Discussion topic: Router not delivered, returned to sky
This message was authored by: HarryRobertson
My router was returned to Sky due to wrong address. How can I get in touch with them to fix this?
Re: Router not delivered, returned to sky
@HarryRobertson
If you are new to the forum then welcome to the Community, which is predominantly made up of Sky customers helping other Sky customers. You aren’t talking to Sky by posting here.
Are you saying your address is incorrect on your account?
These are the current methods available for contacting Sky. Depending on the reason for making contact some will be more appropriate than others.
🟢📞 Call Customer Services by dialling 150 (free) from either a Sky mobile or your Sky Talk landline if you’re a Sky Broadband customer. The forum doesn’t allow the display of other numbers but official numbers to Sky from the UK are 03 numbers which are usually inclusive from non Sky phones.
Note: If your Sky services are restricted due to a missed payment, calling will only result in a request to pay.
All calls will start automated (aka ‘the bot’) which may offer you the online help route or try to send you here to the forum. Stay on the line as long as possible and sometimes saying nothing when asked the reason for the call helps being put in the queue for an agent.
🟢online help via this link
https://www.sky.com/help
🟢Sky Assistant 💬 should also be available via
🟢Social Media You can also get in touch via the messaging services on Facebook or Instagram, (links at the bottom of the forum page).
♦️Note ~ ROI customers If you’re in the ROI make sure the flag in the bottom right of any link is showing the correct flag and change if required. The Sky Ireland phone lines have different operating hours to the UK and are closed over a weekend.
