Discussion topic: Router keeps loosing its connection
Message posted on 28 Jul 2026 10:08 AM
Message posted on 28 Jul 2026 10:13 AM
Re: Router keeps loosing its connection
@DawnFeathersto
Start by using this link to check if there are any issues locally that may identify a known fault which could be affecting multiple households ~
If you’re still having problems you may need to report it to Sky again. The easiest way is to dial 150 free from your Sky Talk landline (if it’s still working).
Working from home?; Sky broadband discussed on here is a domestic service and whilst Sky allow customers working from home to use it, they won’t receive additional or quicker support.
@DawnFeathersto wrote:
Hi for the last 2 weeks now, my broadband keeps dropping multiple times a day the middle light on router goes orange, I have spoken to someone on the phone the other day, they ran tests and said everything appears to be working normally, which cause the problem is still happening and I still having to reboot router each time . Can we please sort this.
Hi @DawnFeathersto Is this Sky Q TV problem (this community) or a broadband problem? Note you are only asking other custoners, not Sky.
Message posted on 28 Jul 2026 10:15 AM
Sorry @MightyQuinn our posts crossed. I've already moved it to the Broadband board.
