Discussion topic: Router keeps dropping out
Message posted on 03 Mar 2025 07:49 PM
Keep losing internet lights 4 and 4 on router go amber, have unplugged and reset router but still dropping out
Message posted on 04 Mar 2025 04:40 AM
Re: Router keeps dropping out
Not sure what 'lights 4 and 4' are but this link providers information about the coloured lights on the various hubs
