Discussion topic: Router issues
Message posted on 14 Jul 2025 09:27 AM
Router issues
My router went off for 5 hours on Friday which they stopped all devices and the tv working - this was all back to normal on Saturday but I want to check the router is the best available as I do not want this happening again as it caused major issues for an autistic person in the household I have the sky broadband hub
Message posted on 14 Jul 2025 09:42 AM
Re: Router issues
That sounds like there was an issue with the broadband being delivered to your property that was outside somewhere, so what hub yiou have doesn't come into it.
Message posted on 14 Jul 2025 09:46 AM
Re: Router issues
The main issue was we had no internet for over 5 hours so I presume this needs checking by sky outside of the home
Message posted on 14 Jul 2025 10:22 AM
Re: Router issues
Can the account be checked as I don't want the autistic adult having to suffer again due to everything not working
Message posted on 14 Jul 2025 10:29 AM
Re: Router issues
You could try running the line test here to see if any faults are found:
If it shows no issues then all is good at present as no system is gouing to be able to tell in advance when an external fault might occur.
Message posted on 14 Jul 2025 12:36 PM
Re: Router issues
@trixiebelle71 You may wish to have sky check, but on the Forum not the place to be doing it, will require you to call sky, you should also look for a backup method if you are going to rely so heavily on having Broadband at all times!
