Discussion topic: Router internet light not on
Message posted on 11 Jan 2026 10:43 AM
Internet patchy for 3 days. Now completely gone. No internet light on router but everything plugged in. No issues in area apparently.
Message posted on 11 Jan 2026 10:44 AM
Re: Router internet light not on
@GGwill
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
Message posted on 11 Jan 2026 10:51 AM
All tests saying fine. Internet light goes briefly green when test is run then orange then come goes blank again.
Very intermittent.
Message posted on 11 Jan 2026 10:53 AM
Could be time to contact Sky then as advised above.
