Discussion topic: Router failure
This message was authored by: Roittie4007
Router failure
Im getting no connection to router or Internet, I have switched of and disconnected but still no connection
Re: Router failure
@Roittie4007 check the lights on the hub and use this guide https://www.sky.com/help/articles/hub-lights-explained-start
This message was authored by: Sam532
Re: Router failure
I've tried that all the lights are on. I've checked my speeds etc on app all connected no problem when I try to connect to it says problem with broadband
