Discussion topic: Router Fault
This message was authored by: MartynH
Router Fault
My Router keeps restarting, this is happening three or four times a day
Re: Router Fault
@MartynH Could be absolutely anything but here if you wish to check below!
Try running the line test here to see if any faults are found:
