Discussion topic: Ring doorbell
Message posted on 24 Jun 2026 08:57 AM
Ring doorbell
my door bell was working perfectly 2 weeks ago, now it will not show the live feed, it says it cannot connect to the wifi, everything is working on. wifi, the ring signal is strong. please can anyone suggest what the problem is.
I have checked with Ring and they say its a wifi issue, i have checked wifi and all is working.
I have deleted app and re installed but its still not working, i have also reset wifi hub.
Message posted on 24 Jun 2026 09:30 AM
Re: Ring doorbell
Hi @Tan66
Did you try disconnecting & reconnecting the Ring doorbell from your WiFi network? E.g. Set it up again in the app
Message posted on 24 Jun 2026 11:09 AM
Re: Ring doorbell
yes i have tried that and it still does not work.
