Discussion topic: Replacing my sky router
This message was authored by Lewis4 This message was authored by: Lewis4
Hello,
I've been having problems with my sky router and the wifi signal. Gaming is practically impossible and drops out through wifi and unfortunately i don't have a port near to the console.
I'm just wondering what are some of the best gaming router options where i can prioritise my console but still have a strong connection to other. My router information is below;
Router Statistics
System Up Time: 45:08:48
Port Status TxPkts RxPkts Collision Pkts Tx b/s Rx b/s Up Time WAN WANoE 12030534 31938416 0 64493 4736467 45:06:56 LAN Down 0 0 0 0 0 00:00:00 WLAN (2.4 GHz) Up 743487 63643 0 15530 18 45:07:04 WLAN (5 GHz) Up 63419511 13011445 0 0 0 45:07:01
Broadband Link Downstream Upstream Connection Speed 0 kbps 0 kbps
This message was authored by mae-3 This message was authored by: mae-3
Re: Replacing my sky router
@Lewis4
A slightly better option than wireless is ethernet homeplugs for the games console.
Lewis4
Any idea on what gaming router would work to boost signal strength?
@Lewis4
Wireless routers output similar power and therefore you'd only get a slightly better signal with a commercial wireless router. But if you want to try a wireless router your best option would be a Asus wireless router these work well with Sky.
