Discussion topic: Replacing Sky Router
Message posted on 26 Mar 2024 07:03 PM
Hi all!
I currently have FTTP connection and have a TP-Link Deco M5 Mesh setup, my aim is to replace the Sky router with any other one that can be put into bridge mode (or equivelant) and let the Deco setup take care of all the routing. I have tried other routers in the past but they either wont work with FTTP or dont have a bridge mode.
Has anyone else got a similar setup and would be able to suggest a new router for me?
Thanks in advance 🙂
Message posted on 28 Mar 2024 10:57 AM
Re: Replacing Sky Router
You do not need a router that had bridge mode, when using FTTP the Openreach ONT is your modem so the router connecting to that will just be a router and will be the device to authenticate on your line.
If you want to use the TP-Link deco system you'll have to try getting it to work via IPv6 as I do not believe it supports DHCP Option 61 authentication which is what is required for traditional IPv4 authentication.
Alternatively you could look at getting a different third party router such as an Asus as they are known to work.
Message posted on 28 Mar 2024 12:20 PM
I never thought of trying that! I will give it a go! thanks!
can you get any adapters for the VOIP phone to still work, ive seen some but im not sure that would work in the way i want too.
This is what im looking at https://www.amazon.co.uk/gp/product/B01N6WN3YZ/ref=sw_img_1?smid=A3GL1BA201XJVN&psc=1
Message posted on 28 Mar 2024 01:03 PM
No, if you still want to use Sky Voice you MUST keep the Sky router in place. The Sky router does not have modem mode either.
Message posted on 28 Mar 2024 07:11 PM
Thanks for info! I got it working direct to the ONT but the wifi keeps dropping intermittently, is there any settings that I need to change to stop this from happening?
Message posted on 02 Apr 2024 10:08 AM
You'd need to check if its just the WiFi or ethernet connections as well because that will tell you whether the router is losing WAN connection or just dropping WiFi connections.
Message posted on 02 Apr 2024 01:33 PM
Hi, it was just wifi that was dropping - everything wired was working fine
Message posted on 02 Apr 2024 01:47 PM
In which case thats a question for TP-Link as the Sky line has nothing to do with the WiFi radios on the Deco system
Message posted on 17 Apr 2024 02:09 PM
hi @AliDray. were you able to get the wifi from dropping? Also, can you share the settings/steps that you used to get the TP-Link Deco connected directly. Thx
