Discussion topic: Replacement power cable wifi
This message was authored by: Chelseari
Message posted on 11 Mar 2026 08:57 AM
My wifi power cable does not work, looking for a replacement. Amazon only have the puck power cable which is smaller than the hub size.
any suggestions where i can order a new one from, as its inpossible to get through to sky!
Message posted on 11 Mar 2026 09:17 AM
Re: Replacement power cable wifi
@Chelseari You are best to call sky and get a complete replacement unit sent. The connector is just not a standard size, so without adapters you will struggle to get a replacement from the likes off amazon!
