Discussion topic: Replacement Router Questions (Sky Fibre)
Message posted on 26 Dec 2025 11:58 PM
Hi,
I have had nothing but issues with the Sky Max Hub and looking at replacing it.
I am looking at (ASUS TUF Gaming AX6000 Dual Band WiFi 6 Extendable Gaming Router) as i read this is compatible with Sky Fibre.
Just unsure what is involved with setup etc... if i was to replace. Can anyone point me in the right direction.
Thanks in advance
Message posted on 27 Dec 2025 05:32 AM
Re: Replacement Router Questions (Sky Fibre)
@azza19892 Asus routers are a popular choice and work well this thred explains the settings to use (and avoid). Assume you are aware that you will lose use of Sky's digital voice line if you replace the Sky hub?
Message posted on 27 Dec 2025 10:32 AM
@azza19892 If you also search for XT8 in the Forum search bar, you will come across some setting's screen's use them as a guidance as zen wifi is common across the Asus platform!
