Discussion topic: Replace sky max hub
This message was authored by: OliviaSmith02
Replace sky max hub
Hi, I have an account set up with sky and would like to replace the sky max hub as it is not working. Is there a way to buy the sky max hub linked to my account?
Many thanks
Olivia
Re: Replace sky max hub
@OliviaSmith02 The sky Max hub is loaned to you from sky, you are not allowed to buy it from them and will be requested to return it when you decide to cancel in the future, if not working do not understand why you would want to buy it, call sky and have it replaced if they find that it is faulty when the test remote for you!
