Discussion topic: Removing a device added via WPS
This message was authored by: MukkaG
Hi, very green newbie here. I've added a device via the wps button to my router, how can I remove the said device please?
Re: Removing a device added via WPS
@MukkaG you need to go into the devices menu and do it from there you cannot disconect devices using the hub's interface. Simplybtirning the device off usuall works.
Avatar for MukkaG
Thank you
