Discussion topic: Removing Connected Devices
This message was authored by: NJ12341
I have a Sky Hub Max subscription which was purchased with the intent to control devices that connect to the router. However, I have zero ability to make those changes and it is adversely affecting other devices (i.e. Peloton continues to drop, even though it worked fine a month ago).
Unfortunately, I have a U.S. phone, so MySky is not available in my "region" even though I live in the UK. Is there a way to access the same controls via the internet/website? If not, this is patently unacceptable -- I shouldn't be obligated to download an app to manage my router. No doubt there are many people that cannot/choose not to download an app.
What can I do to A) access devices controls, B) access MySky or MySky functionality without the app, or resolve my connectivity problems?
Thank you for the help.
This message was authored by: peter-marlow+1966
Re: Removing Connected Devices
So you can not download  the my sky app on any device and log in?
P c marlow
Avatar for NJ12341
Correct. I cannot download it.
I'm on the phone with Sky and they said I'd have to change my region -- which would require me cancelling my Apple subscriptions, which I don't want to (and shouldn't have to) do.
Then I would ring sky and talk to them about this issue
P c marlow
@NJ12341 You want to control a sky Max hub, then you need to use the MySky app, just no other way, so if you wish to do so with a PC or Mac, then emulator will be the way to go!
