Discussion topic: Remove a laptop from my WiFi
Message posted on 08 Oct 2026 10:10 AM
I have a laptop I didn't authorise using my WiFi , I have changed the password but it still seems to be able to log on to my WiFi
Message posted on 08 Oct 2026 11:50 AM
Re: Remove a laptop from my WiFi
@Fackrell34 wrote:I have a laptop I didn't authorise using my WiFi , I have changed the password but it still seems to be able to log on to my WiFi
It's impossible to log on to any wifi network without the SSID and password, so if it's true that they're still using your wifi then they've accessed your password (or guessed a really simple one).
If the laptop is within the same household are you sure they're using the wifi and not an ethernet cable?
Not a Sky employee
Sky FTTP 500Mb to Max Hub
