Discussion topic: Remote access
Message posted on 11 Jun 2026 08:05 AM
Remote access
is it possible to turn my WiFi off remotley?
Message posted on 11 Jun 2026 08:08 AM
Re: Remote access
@RitSueNBob2 wrote:is it possible to turn my WiFi off remotley?
That depends on your definition of "remotely". You need to be within wifi range of the router or on the same Lan. It can't be done from outside the house or at least not by the user.
Not a Sky employee
Sky FTTP 500Mb to Max Hub (WiFi disabled)
Pair of TP-Link Deco BE65's in AP mode used for WiFi access, main Deco hardwired to Max hub
Message posted on 11 Jun 2026 08:11 AM
Re: Remote access
Thank you, sometimes my children over use it when im at work so wanted the option of turning it off in the app or some way.
Message posted on 11 Jun 2026 08:15 AM
Re: Remote access
https://www.sky.com/help/articles/sky-wifi-max-parental-controls
