Discussion topic: Regarding wif
Message posted on 31 Jan 2026 02:16 AM
Regarding wif
I'm not happy with my WiFi for the past week it's been lagging and the past 2 nights it's gone off. Tried to reset it and turned it off but still not working
Message posted on 31 Jan 2026 05:35 AM
Re: Regarding wif
@VickyH77-
Any broadband issues between midnight and 7am could be essential overnight maintenance taking place which is carried out then to minimise disruption. There’s no pre-warning of this. See this pinned post at the top of the Broadband board from Sky which could be relevant any night this happens…
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/td-p/5151847...
If you have an ONT box displaying a red light, see this further advice…
This link provides information about the coloured lights you may see on the various hubs
Hopefully it’s back up and running before 7am. If it’s not, try restarting your hub or post back in this thread and we can try to offer additional advice.
Re: Regarding wif
When it is down after midnight to around 6am then it could be overnight maintenance taking place as per this message at the top of the page:
https://helpforum.sky.com/t5/Broadband/Important-Notice-Scheduled-Broadband-Maintenance/m-p/5151847#...
If it still down later then the first thing to check is this link to see if there are any outages in your area, it doesn't always pick up issues straight away so it might be worth trying again later if this is the case:
If your ONT shows a red light then have a read of this:
If there isn't try running the line test here:
