Discussion topic: Ref hive connection to hub
This message was authored by: Butler007
I am finding out from sky that my hive is affecting my router does any one have an answer
Re: Ref hive connection to hub
@Butler007 i have had the Hive system for some years and apart from being quite fussy about connecting the Hive hub to the Sky hub I have never had an issue. What symptoms do you get?
