Discussion topic: Red light
This message was authored by: Jamie-
Red light
I have no broadband connection and red light won't go away,I have tried everything and nothing works
Re: Red light
@Jamie-
With any broadband issue the first thing to do (even if you’ve already tried it), is use this link to check if there are any outages or issues nearby that may identify a known fault, perhaps affecting multiple households ~
