Discussion topic: Red light on router
Message posted on 26 Nov 2025 08:08 AM
Red light on router
Red light on the router and it was working last night until 11 and now nothing. Have looked online and it says lots are having the same issue and you are saying nothing is wrong
Message posted on 26 Nov 2025 08:14 AM
Re: Red light on router
@Trev680
Even if you’ve already tried it use this link to check to see if there are any broadband issues or outages nearby ~ (it doesn’t necessarily disclose a problem immediately and it can take an hour+ to update so perhaps try it again later).
