Discussion topic: Red light on router – internet connection issue
Message posted on 30 Mar 2026 03:13 PM
Message posted on 30 Mar 2026 04:24 PM
Re: Red light on router – internet connection issue
If you have Sky Fibre and your ONT shows a red light then have a read of this:
If nothing there helps then the first thing to check is this link to see if there are any outages in your area, it can be a bit slow at picking up issues so if nothing shows perhaps try it again later:
If there isn't try running the line test here:
