Discussion topic: Red light on los
This message was authored by: Clcole240775
Red light on los
No internet .
Re: Red light on los
@Clcole240775
The first thing to try, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
It doesn’t necessarily disclose a problem immediately and there is up to an hours delay before the service checker picks up a lost connection so perhaps try it again later.
This should determine if there's an identified fault, perhaps affecting multiple households. If there aren't any then try running the line test here
