Discussion topic: Red light on broadband box
This message was authored by: Fd1874
My middle red light on broadband box keeps going on and off and I keep losing WiFi, I have tried taken it off and rebooted my sky box this is important,  not just tv but I need it for my work as work from home
Re: Red light on broadband box
@Fd1874
See further down for guidance on the lights on the various hubs.
For broadband issues the first thing to do, even if you’ve already tried it, is to use this link to check to see if there are any broadband issues or outages nearby ~
This should identify if there's a known fault, perhaps affecting multiple households.
